Isopropyl Alcohol Question
  • Isopropyl Alcohol Question
    I went to buy some ISA the other day and found that there were two different concentrations available - 76% and 91% (may be slightly off on the %'s). Two questions - which one is recommended for checking swirl removal and does it need to be diluted before applying to an area?
    Thanks.
    2013 Highlander - black
    2010 TL - black
    Re: Isopropyl Alcohol Question
    I get the 91% stuff and mix it 1:1 with water.
    Scott
      Don't think there's ever been any "Official Recommendation" from all the powers that be so here you go...
      The official recommendation for which concentration of Isopropyl Alcohol to purchase when mixing a bottle of Isopropyl Alcohol and water for stripping paint for inspection is to purchase the standard 91% concentration version.
      There, you read it here first.
        Actually, this topic was addressed a year or so ago in these two threads although I don't think they were ever positioned with the official annoiting...
        From 2007...
        Worried the Dealership instill Swirls into my new paint job?
        M83 rocks with a rotary! What next?
        From 2008
        I may have screwed up my 1999 Corvette
        Note the below bottle of Isopropyl Alcohol is the 90% Alcohol version, not the 50% version, this way when you mix it with water you have closer to a true 50% mixture of water to alcohol and one bottle plus the water will fill up the nice Rubbermaid generic spray bottle. It's about the same price as the weaker version and can be found at most Target stores as can the Rubbermaid spray bottle.
          I was only ever able to get the 70-75%.
          Didn't know there was a 90%
          Now,i can't get either.
            Eddie, I could get 99% here... I mixed it 1:1 with distilled water for checking my polishing progress. I had some solution contact my bleeding wound and man was it painful! Because of this experience, I dilute my alchol with more water, just in case I get some on my wounds.
            70% works too of course. Just dilute it less to make the alcohol content stronger.
              Didn't know there was 99%?
              If you look at the pic in Mike's thread,that example is the 70% that I was able to get in the past.
                I use cheap tequila
                  You can get 1/2 gallon of 70% at Walgreens for $3: http://www.walgreens.com/search/resu...propyl+alcohol
                  AeroCleanse, LLC
                  www.aerocleanse.com
                    If I wanted to order 1/2 gallon here,it would cost me about $30!
                    Can you believe that!..... I can't order less than a gallon. $60's please.
                    That's why I don't buy it. It's just not a popular thing here. In the past,I could at least buy 1/2 a litre,which was okay.
                      What about wax and grease remover from a body shop supply store?
                      Sherwin-Williams Automotive Finishes is the leading manufacturer and distributer of high-quality paint and coating systems for automotive and fleet refinishing industries.
                        Walgreens Apothecary Isopropyl Rubbing Alcohol 70%
                        Size/Count 16.0oz.
                        Price 2/$3.00
                          Well at least your wound was cleaned, haha!
                          -HealthyCivic
                          Check out the glossary
                            Let's just say that someone forgot to dilute IPA 1:1 with water, what would happen?
                            BobbyG
                              id have to say......nothing. just a good old stripping of wax.
                              ive used IPA just straight out of the bottle with no bad effects at all.
                              Addicted
